[postgis-devel] [PostGIS] #1542: tickets.sql tests fail
PostGIS trac at osgeo.org
Mon Feb 6 12:34:54 PST 2012
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by pramsey):
 Is it possible that the proj includes files you are building against are
 different that the proj .so file you are linking against? The errors say
 to me: the spheroid is being initialized with the wrong numbers, but the
 only mechanism I can see for that to happen would be if the interpretation
 of the PJ struct is incorrect somehow.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1542#comment:6>
