[postgis-devel] [PostGIS] #1532: Have regress install the comments and throw an error if failure
trac at osgeo.org
Tue Feb 7 05:25:02 PST 2012
Reporter: robe | Owner: strk
Type: enhancement | Status: new
Priority: high | Milestone: PostGIS 2.0.0
Component: build/upgrade/install | Version: trunk
Keywords: |
Changes (by robe):
* priority: medium => high
Comment:
I was saying that if XSLTPROC is installed then regress should test the
comments otherwise it shouldn't. We've got a lot of conditional tests
testing for those various versions of geos. Is it hard to make one that
runs only if XSLTPROC is installed?
To be truthful, I don't care about this test, as long as you try to
install postgis , postgis_topology using the extension module before you
release an alpha tar ball. In fact I see no reason why the tar balls
can't include already generated extension files since those files are the
same regardless of if you are on Unix, Linux, MacOSX or Windows. I just
don't want to come to the point of building a windows binary to distribute
and "Yikes, gosh, darn it - the extensions won't install. I'll have to
hack them or forgo distributing the binaries".
We've got lots of windows testers out there who rely on pre-made binaries
and can help us squeeze out what bugs we have remaining. I want to USE
THEM. :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1532#comment:3>
