[postgis-devel] [PostGIS] #1551: topology regression failures
PostGIS trac at osgeo.org
Tue Feb 7 15:41:38 PST 2012
 Reporter:  gdt       |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 With r9078, running "gmake check" in topology results (consistently)
 in 3 failed tests on:
   PostGIS is now configured for i386-unknown-netbsdelf5.1.
  -------------- Compiler Info -------------
   C compiler:           gcc -g -O2
   C++ compiler:         g++ -g -O2
  -------------- Dependencies --------------
   GEOS config:          /usr/pkg/bin/geos-config
   GEOS version:         3.3.2
   GDAL config:          /usr/pkg/bin/gdal-config
   GDAL version:         1.8.1
   PostgreSQL config:    /usr/pkg/bin/pg_config
   PostgreSQL version:   PostgreSQL 9.1.2
   PROJ4 version:        47
   Libxml2 config:       /usr/pkg/bin/xml2-config
   Libxml2 version:      2.7.8
   JSON-C support:       no
   PostGIS debug level:  0
   Perl:                 /usr/pkg/bin/perl
  --------------- Extensions ---------------
   PostGIS Raster:       0.1.6d
   PostGIS Topology:     enabled
  -------- Documentation Generation --------
   xsltproc:             /usr/pkg/bin/xsltproc
   xsl style sheets:     /usr/pkg/share/xsl/docbook
   dblatex:
   convert:              /usr/pkg/bin/convert
   regress/st_createtopogeo .. failed (diff expected obtained:
 /tmp/pgis_reg_2996/test_17_diff)
  regress/st_getfacegeometry .. ok
  regress/st_getfaceedges .. ok
  regress/st_modedgeheal .. ok
  regress/st_modedgesplit .. ok
  regress/st_newedgeheal .. ok
  regress/st_newedgessplit .. ok
  regress/st_remedgenewface .. ok
  regress/st_remedgemodface .. ok
  regress/topoelement .. ok
  regress/topoelementarray_agg .. ok
  regress/topogeo_addlinestring .. failed (diff expected obtained:
 /tmp/pgis_reg_2996/test_28_diff)
  regress/topogeo_addpoint .. ok
  regress/topogeo_addpolygon .. failed (diff expected obtained:
 /tmp/pgis_reg_2996/test_30_diff)
 --- regress/st_createtopogeo_expected   2012-01-12 20:47:34.000000000
 -0500
 +++ /tmp/pgis_reg_2996/test_17_out      2012-02-07 18:35:19.000000000
 -0500
 @@ -6,7 +6,7 @@
  T1|POINT(0 0)
  T1|1 nodes|0 edges|0 faces
  T2|SRID=4326;LINESTRING(0 0,8 -40)
 -T2|2 nodes|1 edges|0 faces
 +T2|4 nodes|1 edges|0 faces
  T3|SRID=4326;POLYGON((0 0,8 -40,70 34,0 0))
  T3|1 nodes|1 edges|1 faces
  T4|SRID=4326;POLYGON((0 0,10 0,10 10,0 10,0 0),(5 5,8 9,4 2,5 5))
 @@ -14,7 +14,8 @@
  T5|MULTIPOINT(0 0,5 5,0 0,10 -2,5 5,0 0)
  T5|3 nodes|0 edges|0 faces
  T6|MULTILINESTRING((0 0,10 0),(10 0,0 0))
 -T6|2 nodes|1 edges|0 faces
 +T6|4 nodes|1 edges|0 faces
 +T6|2 isolated nodes in face 0
  T7|MULTILINESTRING((0 0,10 0),(5 -5,6 5))
  T7|5 nodes|4 edges|0 faces
  T8|MULTIPOLYGON(((0 0,10 0,10 10,0 10,0 0)),((0 0,0 10,10 10,10 0,0 0)))
 @@ -24,9 +25,11 @@
  T10|MULTIPOLYGON(((0 0,5 10,10 0,0 0)),((0 20,5 10,10 20,0 20)))
  T10|1 nodes|2 edges|2 faces
  T11|GEOMETRYCOLLECTION(LINESTRING(0 0,10 0),POINT(5 0))
 -T11|3 nodes|2 edges|0 faces
 +T11|5 nodes|2 edges|0 faces
 +T11|1 isolated nodes in face 0
  T12|GEOMETRYCOLLECTION(LINESTRING(0 0,10 0),POINT(0 0),POINT(10 0))
 -T12|2 nodes|1 edges|0 faces
 +T12|4 nodes|1 edges|0 faces
 +T12|2 isolated nodes in face 0
  T13|GEOMETRYCOLLECTION(MULTIPOLYGON(((0 0,10 0,10 10,0 10,0 0)),((5 5,5
 15,15 15,15 5,5 5),(10 10,12 10,10 12,10 10))),LINESTRING(0 0,20
 0),MULTIPOINT(0 0,10 0,5 0),MULTILINESTRING((0 0,10 0),(10 0,15
 5)),POINT(5 0),POINT(10.5 10.5),POINT(100 500))
  T13|10 nodes|12 edges|5 faces
  T13|1 isolated nodes in face 0
 @@ -37,6 +40,7 @@
  T15|GEOMETRYCOLLECTION(LINESTRING(-5 -2,0 0),LINESTRING(0 0,10
 10),LINESTRING(0 0,5 2,10 10),LINESTRING(10 10,12 10))
  T15|4 nodes|4 edges|1 faces
  T16|GEOMETRYCOLLECTION(LINESTRING(0 0,10 0),LINESTRING(0 3,20
 4),LINESTRING(10 0,20 4))
 -T16|4 nodes|3 edges|0 faces
 +T16|5 nodes|1 edges|0 faces
 +T16|3 isolated nodes in face 0
  T17|MULTILINESTRING((832709.937 816560.25,832705.813 816470.25,832661.937
 816561.875),(832705.812 816470.25,832709.937 816560.25),(832661.938
 816561.875,832705.813 816470.25))
  T17|7 nodes|8 edges|2 faces
 --- regress/topogeo_addlinestring_expected      2012-01-22
 15:32:36.000000000 -0500
 +++ /tmp/pgis_reg_2996/test_28_out      2012-02-07 18:35:23.000000000
 -0500
 @@ -16,83 +16,88 @@
  N|25||POINT(37 20)
  N|26||POINT(41 16)
  E|28|sn25|en26
 -iso_ex|27
 -iso_ex_tol|27
 -noniso_ex|18
 -noniso_ex_tol|18
 -contained|29
 -N|27||POINT(35 8)
 -N|28||POINT(35 12)
 -E|18|sn10|en27
 +iso_ex|29
 +N|27||POINT(-0.2 -0.2)
 +N|28||POINT(0 30)
  E|29|sn27|en28
 -E|30|sn28|en13
 -overlap|31
 -overlap|32
 -N|29||POINT(49 22)
 -N|30||POINT(45 22)
 -E|8|sn18|en30
 -E|31|sn19|en29
 -E|32|sn30|en19
 -cross|34
 -cross|35
 -N|31||POINT(49 18)
 -N|32||POINT(47 17.6)
 -N|33||POINT(44 17)
 -E|15|sn12|en32
 -E|33|sn32|en19
 -E|34|sn31|en32
 -E|35|sn32|en33
 +iso_ex_tol|29
 +noniso_ex|30
 +N|29||POINT(0 14)
 +E|30|sn27|en29
 +noniso_ex_tol|30
 +contained|31
 +N|30||POINT(35 8)
 +N|31||POINT(35 12)
 +E|18|sn10|en30
 +E|31|sn30|en31
 +E|32|sn31|en13
 +overlap|33
 +overlap|34
 +N|32||POINT(49 22)
 +N|33||POINT(45 22)
 +E|8|sn18|en33
 +E|33|sn19|en32
 +E|34|sn33|en19
 +cross|36
 +cross|37
 +N|34||POINT(49 18)
 +N|35||POINT(47 17.6)
 +N|36||POINT(44 17)
 +E|15|sn12|en35
 +E|35|sn35|en19
 +E|36|sn34|en35
 +E|37|sn35|en36
  snap|7
 -snap|36
 -snap|39
 -N|34||POINT(18 22)
 -N|35||POINT(22.4 22)
 -N|36||POINT(21 20.4)
 -E|6|sn16|en34
 -E|7|sn17|en35
 -E|19|sn14|en36
 -E|36|sn34|en17
 -E|37|sn35|en18
 -E|38|sn36|en17
 -E|39|sn35|en36
 -snap_again|7
 -snap_again|36
 -snap_again|39
 -crossover|42
 -crossover|44
 +snap|38
 +snap|41
 +N|37||POINT(18 22)
 +N|38||POINT(22.4 22)
 +N|39||POINT(21 20.4)
 +E|6|sn16|en37
 +E|7|sn17|en38
 +E|19|sn14|en39
 +E|38|sn37|en17
 +E|39|sn38|en18
 +E|40|sn39|en17
 +E|41|sn38|en39
 +snap_again|41
 +snap_again|42
 +E|42|sn27|en38
  crossover|45
 -crossover|46
 -N|37||POINT(9 20)
 -N|38||POINT(16.2 14)
 -N|39||POINT(21 10)
 -N|40||POINT(9 18)
 -N|41||POINT(21 7)
 -E|9|sn15|en38
 -E|20|sn9|en41
 -E|21|sn15|en40
 -E|40|sn37|en16
 -E|41|sn38|en14
 -E|42|sn37|en38
 -E|43|sn39|en14
 -E|44|sn38|en39
 -E|45|sn40|en37
 -E|46|sn41|en39
 -crossover_again|42
 -crossover_again|44
 +crossover|47
 +crossover|48
 +crossover|49
 +N|40||POINT(9 20)
 +N|41||POINT(16.2 14)
 +N|42||POINT(21 10)
 +N|43||POINT(9 18)
 +N|44||POINT(21 7)
 +E|9|sn15|en41
 +E|20|sn9|en44
 +E|21|sn15|en43
 +E|43|sn40|en16
 +E|44|sn41|en14
 +E|45|sn40|en41
 +E|46|sn42|en14
 +E|47|sn41|en42
 +E|48|sn43|en40
 +E|49|sn44|en42
  crossover_again|45
 -crossover_again|46
 +crossover_again|47
 +crossover_again|48
 +crossover_again|49
  contains|25
 -contains|47
 -contains|48
 -N|42||POINT(14 34)
 -N|43||POINT(7 36)
 -E|47|sn42|en22
 -E|48|sn21|en43
 -nodecross|49
 -nodecross|50
 -N|44||POINT(18 37)
 -N|45||POINT(22 37)
 -E|49|sn44|en4
 -E|50|sn4|en45
 -iso_ex_2segs|28
 +contains|50
 +contains|51
 +N|45||POINT(14 34)
 +N|46||POINT(7 36)
 +E|50|sn45|en22
 +E|51|sn21|en46
 +nodecross|52
 +nodecross|53
 +N|47||POINT(18 37)
 +N|48||POINT(22 37)
 +E|52|sn47|en4
 +E|53|sn4|en48
 +ERROR:  SQL/MM Spatial exception - geometry crosses an edge
  Topology 'city_data' dropped
 --- regress/topogeo_addpolygon_expected 2012-01-12 20:47:34.000000000
 -0500
 +++ /tmp/pgis_reg_2996/test_30_out      2012-02-07 18:35:25.000000000
 -0500
 @@ -24,31 +24,30 @@
  ex_union|6
  ex_union|7
  half|4
 -E|30|sn14|en18
 -F|13
 +N|26||POINT(0 -0.2)
 +N|27||POINT(0 22)
 +E|30|sn26|en27
  split|4
 -split|13
 -N|26||POINT(28 18)
 -E|30|sn14|en26
 -E|31|sn26|en18
 -E|32|sn17|en26
 -E|33|sn26|en13
 -F|14
 -F|15
 +E|31|sn17|en13
 +F|13
  ex_hole|3
 +ex_hole|4
  ex_hole|5
  ex_hole|6
  ex_hole|7
  ex_hole|8
  ex_hole|13
 -ex_hole|14
 -ex_hole|15
 +N|28||POINT(0 -0.2)
 +N|29||POINT(0 18)
 +N|30||POINT(28 18)
 +E|31|sn17|en30
 +E|32|sn28|en29
 +E|33|sn30|en13
  ex_hole_snap|3
 +ex_hole_snap|4
  ex_hole_snap|5
  ex_hole_snap|6
  ex_hole_snap|7
  ex_hole_snap|8
  ex_hole_snap|13
 -ex_hole_snap|14
 -ex_hole_snap|15
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1551>
