[postgis-devel] [PostGIS] #1541: Stop relying on private projects.h PROJ header
trac at osgeo.org
Wed Feb 8 09:56:36 PST 2012
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.0
Component: build/upgrade/install | Version: trunk
Keywords: |
Comment(by pramsey):
Not sure what the final version of trunk will be, though I would guess
something like changing the API would warrant a larger version bump than
4.7.1. Regardless Frank *does* intend to stop installing projects.h so for
trunk support we need to have an API to spheroid info, but there's a
ticket on that. The question is what to do for earlier versions of proj.
To disable the spheroid SRID support, or to use projects.h.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1541#comment:8>
