[postgis-devel] [PostGIS] #547: ST_contains memory problem when used between polygon and mixed geometry
trac at osgeo.org
Thu Feb 9 08:29:53 PST 2012
Reporter: twain | Owner: strk
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.5.X
Resolution: | Keywords: ST_contains memory
Comment(by pramsey):
The PrepGeom stuff is confusing because it has to account for the memory
being allocated by GEOS outside the PgSQL memory pools and clean it up on
shutdown. It does this with the crazy-making memory context stuff you're
squinting at. The proj cache has the same stuff. The memory leak might be
because your unified cache work has not taken those issues into account?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/547#comment:17>
