[postgis-devel] [PATCH] Building postgis trunk with argument --without-topology isn't working
serveralex
serveralex at gmail.com
Thu Feb 9 12:30:39 PST 2012
Hello,
the build with ./configure --without-topology is broken. Make tries to
build the extensions/postgis_topology, which
doesn't work obviously. I did some adjustments to the build files. The
patch is attached to this email.
Regards,
Alex
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120209/18dd5b20/attachment.obj>
