[postgis-devel] Regression performance.
Sandro Santilli
strk at keybit.net
Thu Feb 9 12:47:33 PST 2012
On Thu, Feb 09, 2012 at 12:20:45PM -0800, David Zwarg wrote:
> Hello,
> I was profiling the performance of the changes that happened in r9112, and
> it turned out to be very significant to pass and evaluate integers in the
> prepared expression. Sticking with float8 values for the x and y positions
> of the pixel contain significant performance benefits (although
> counter-intuitive).
> I've changed the x and y positions in 1 raster map algebra back to float
> values for performance reasons.
> These are my metrics for running 5 sets of 10 rasters, each 500x500 pixels,
> from one of the SRTM tiles linked to by the WKTRaster tutorial page. Times
> are in milliseconds. The first column is revision 9112 (removal of strstr
> in the pixel loop, using integer as x and y pixel values), the second
> column is that same revision (with a modification to use float8 instead of
> int32 for x and y pixel coordinates), the third column is revision 9111
> (using strstr in the pixel loop), the fourth column is the incorporation of
> this change into the HEAD revision as of this morning (more memory
> allocations have been moved out of the pixel loop).
The numbers for those like me not willing to fire a graphical browser:
r9112 r9112-int r9111 r9137
9839.746 8473.403 9094.589 7820.646
6228.067 5329.813 5763.88 4738.372
8749.516 7441.936 7893.893 6866.745
13618.762 11254.392 12177.314 10780.401
6233.851 5442.746 5730.231 4767.192
I'm really surprised. Which version of PostgreSQL were you using ?
I'm still not convinced we should pretend numbers are float though.
It was changed back for a reason:
http://trac.osgeo.org/postgis/ticket/1557
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.0 !
| / 2.0 | http://strk.keybit.net
`-o------'
