[postgis-devel] [PostGIS] #1505: Deal with database dumps containing geometries with SRID > MAX_SRID
trac at osgeo.org
Fri Feb 10 08:06:48 PST 2012
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by strk):
in turn this means that we _have_ to accept SRIDs in the range
999000..999999 anyway, which means we have to raise (or drop) the check on
spatial_ref_sys. At that point why not reusing the range _also_ for
lost+found ? Clamping is a corner-case operation anyway, and must/will be
noisy. It's currently an EXCEPTION.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1505#comment:18>
