[postgis-devel] Problem executing the regression tests on Windows 7
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Fri Feb 10 08:35:47 PST 2012
When trying to execute the regression  tests on Windows 7, I get:
make[4]: Entering directory `/c/projects/postgis/postgis'
/bin/mkdir -p 'c:/projects/postgis/regress/00-regress-install/lib'
/bin/mkdir -p 'c:/projects/postgis/regress/00-regress-install/share/contrib/postgis'
/bin/sh c:/projects/pg/pg90/lib/POSTGR~1/pgxs/src/MAKEFI~1/../../config/install-sh -c -m 755  postgis-2.0.dll 'c:/projects/postgis/regress/0
0-regress-install/lib/postgis-2.0.dll'
/bin/sh c:/projects/pg/pg90/lib/POSTGR~1/pgxs/src/MAKEFI~1/../../config/install-sh -c -m 644 ./../spatial_ref_sys.sql postgis.sql uninstall_
postgis.sql postgis_upgrade_20_minor.sql legacy.sql uninstall_legacy.sql legacy_compatibility_layer.sql 'c:/projects/postgis/regress/00-regr
ess-install/share/contrib/postgis/'
make[4]: Leaving directory `/c/projects/postgis/postgis'
/bin/perl -pi -e 's,\$libdir,c:/projects/postgis/regress/00-regress-install/lib,g' c:/projects/postgis/regress/00-regress-install/share/contrib/postgis/*.sql
Can't do inplace edit on c:/projects/postgis/regress/00-regress-install/share/contrib/postgis/legacy.sql: Permission denied.
Can't do inplace edit on c:/projects/postgis/regress/00-regress-install/share/contrib/postgis/legacy_compatibility_layer.sql: Permission denied.
Can't do inplace edit on c:/projects/postgis/regress/00-regress-install/share/contrib/postgis/postgis.sql: Permission denied.
Can't do inplace edit on c:/projects/postgis/regress/00-regress-install/share/contrib/postgis/postgis_upgrade_20_minor.sql: Permission denied.
Can't do inplace edit on c:/projects/postgis/regress/00-regress-install/share/contrib/postgis/rtpostgis.sql: Permission denied.
Can't do inplace edit on c:/projects/postgis/regress/00-regress-install/share/contrib/postgis/rtpostgis_drop.sql: Permission denied.
Can't do inplace edit on c:/projects/postgis/regress/00-regress-install/share/contrib/postgis/rtpostgis_legacy.sql: Permission denied.
Can't do inplace edit on c:/projects/postgis/regress/00-regress-install/share/contrib/postgis/rtpostgis_upgrade_20_minor.sql: Permission denied.
Can't do inplace edit on c:/projects/postgis/regress/00-regress-install/share/contrib/postgis/rtpostgis_upgrade_cleanup.sql: Permission denied.
Can't do inplace edit on c:/projects/postgis/regress/00-regress-install/share/contrib/postgis/spatial_ref_sys.sql: Permission denied.
Can't do inplace edit on c:/projects/postgis/regress/00-regress-install/share/contrib/postgis/topology.sql: Permission denied.
Can't do inplace edit on c:/projects/postgis/regress/00-regress-install/share/contrib/postgis/topology_upgrade_20_minor.sql: Permission denied.
Can't do inplace edit on c:/projects/postgis/regress/00-regress-install/share/contrib/postgis/uninstall_legacy.sql: Permission denied.
Can't do inplace edit on c:/projects/postgis/regress/00-regress-install/share/contrib/postgis/uninstall_postgis.sql: Permission denied.
Can't do inplace edit on c:/projects/postgis/regress/00-regress-install/share/contrib/postgis/uninstall_rtpostgis.sql: Permission denied.
Can't do inplace edit on c:/projects/postgis/regress/00-regress-install/share/contrib/postgis/uninstall_topology.sql: Permission denied.
The install command works fine but when perl tries to edit the files it delete them and then display 'Can't do inplace...'.
Any idea?
Thanks,
Pierre
