[postgis-devel] [PostGIS] #1570: in_gml, in_kml crashing and many regrss tests failing on mingw
trac at osgeo.org
Sat Feb 11 20:23:02 PST 2012
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Now that I can regress again testing the alpha4, the ST_GeomFromKML,
ST_GeomFromGML are crashing. This could be changes in my configuration.
Pierre -- getting any crashing and failures on the in_gml, in_kml.
I'm getting a lot of failures, but thoase coudl be the rsult of the
database server restarting while the next set of tests are running.
My make check looks like this:
PostgreSQL 9.1.2, compiled by Visual C++ build 1500, 32-bit
Postgis 2.0.0alpha4 - 2012-02-12 03:24:28
GEOS: 3.3.3dev-CAPI-1.7.3
PROJ: Rel. 4.6.1, 21 August 2008
Running tests
loader/Point ....................... ok
loader/PointM ....................... ok
loader/PointZ ....................... ok
loader/MultiPoint ....................... ok
loader/MultiPointM ....................... ok
loader/MultiPointZ ....................... ok
loader/Arc ....................... ok
loader/ArcM ....................... ok
loader/ArcZ ....................... ok
loader/Polygon ....................... ok
loader/PolygonM ....................... ok
loader/PolygonZ ....................... ok
loader/TSTPolygon ......... ok
loader/TSIPolygon ......... ok
loader/TSTIPolygon ......... ok
loader/PointWithSchema ..... ok
loader/NoTransPoint ......... ok
loader/NotReallyMultiPoint ............... ok
loader/MultiToSinglePoint ......... ok
loader/ReprojectPts ........ ok
loader/ReprojectPtsGeog ........ ok
loader/Latin1 .... ok
binary .. ok
regress .. ok
regress_index .. ok
regress_index_nulls .. ok
lwgeom_regress .. ok
regress_lrs .. ok
removepoint .. ok
setpoint .. ok
simplify .. ok
snaptogrid .. ok
summary .. ok
affine .. ok
empty .. ok
measures .. ok
long_xact .. ok
ctors .. ok
sql-mm-serialize .. ok
sql-mm-circularstring .. ok
sql-mm-compoundcurve .. ok
sql-mm-curvepoly .. ok
sql-mm-general .. ok
sql-mm-multicurve .. ok
sql-mm-multisurface .. ok
polyhedralsurface .. ok
polygonize .. ok
postgis_type_name .. ok
out_geometry .. ok
out_geography .. ok
in_gml .. failed (diff expected obtained:
/tmp/pgis_reg_2176/test_51_diff)
in_kml .. failed (diff expected obtained:
/tmp/pgis_reg_2176/test_52_diff)
iscollection .. failed (diff expected obtained:
/tmp/pgis_reg_2176/test_53_diff)
regress_ogc .. failed (diff expected obtained:
/tmp/pgis_reg_2176/test_54_diff)
regress_ogc_cover .. failed (diff expected obtained:
/tmp/pgis_reg_2176/test_55_diff)
regress_ogc_prep .. failed (diff expected obtained:
/tmp/pgis_reg_2176/test_56_diff)
regress_bdpoly .. failed (diff expected obtained:
/tmp/pgis_reg_2176/test_57_diff)
regress_proj .. failed (diff expected obtained:
/tmp/pgis_reg_2176/test_58_diff)
regress_management .. failed (diff expected obtained:
/tmp/pgis_reg_2176/test_59_diff)
dump .. failed (diff expected obtained: /tmp/pgis_reg_2176/test_60_diff)
dumppoints .. failed (diff expected obtained:
/tmp/pgis_reg_2176/test_61_diff)
wmsservers .. ok
wkt .. ok
wkb .. ok
tickets .. failed (diff expected obtained:
/tmp/pgis_reg_2176/test_65_diff)
typmod .. failed (diff expected obtained:
/tmp/pgis_reg_2176/test_66_diff)
remove_repeated_points .. ok
split .. ok
relate .. ok
bestsrid .. ok
concave_hull .. ok
hausdorff .. ok
regress_buffer_params .. ok
offsetcurve .. ok
relatematch .. ok
isvaliddetail .. ok
sharedpaths .. ok
snap .. ok
node .. ok
unaryunion .. ok
clean .. ok
relate_bnr .. ok
uninstall .. ok (3855)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1570>
