[postgis-devel] [PostGIS] #1494: Ability to load census tract/block data when loading tiger_geocoder with shapefiles
trac at osgeo.org
Mon Feb 13 08:20:30 PST 2012
shapefiles
Reporter: kiwi | Owner: robe
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: trunk
Keywords: |
Comment(by robe):
Have logic to load blockgroups (bg), census tracts (tract) and tabulation
blocks (tabblock) at r9168.
I tested the differential state load on windows, but haven't retested the
full load.
Can you give it a try.
After you run the upgrade script, you just need to do something like
SELECT loader_generate_census(ARRAY['TX'], 'sh');
To load for just the census data for Texas.
As far as functions to use it, haven't thought what things would be most
useful to output given a geometry.
Would the full geoids be too much. Since I deal with just state data, I
usually use the tractce and blkgrpce (from block groups).
I'm thinking of renaming those fields to just tract, blkgrp but I should
probably leave well enough alone.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1494#comment:2>
