[postgis-devel] [PostGIS] #1570: in_gml, in_kml crashing and many regrss tests failing on mingw
PostGIS trac at osgeo.org
Wed Feb 15 11:19:07 PST 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by pracine):
 In my case one of the CUnit test fails:
 Suite: WKT In Suite
   Test: test_wkt_in_point ... FAILED
     1. cu_in_wkt.c:71  - CU_ASSERT_STRING_EQUAL(r,"POINT(inf 0)")
 And many regress fail as well... Mostly the one you identified above.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1570#comment:4>
