[postgis-devel] [PostGIS] #1581: [raster] ST_Clip should not impose a nodata value when the source raster do not have one
trac at osgeo.org
Wed Feb 15 12:04:41 PST 2012
not have one
Reporter: pracine | Owner: pracine
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS Raster 2.0.1
Component: raster | Version: trunk
Keywords: |
In the case where:
1) the input raster do not have a nodata value defined
2) no alternative nodata values are provided
The behavior right now is to set a nodata value to the resulting raster
using ST_MinPossibleValue(ST_BandPixelType(rast)). We should not do
that...
Most users would expect to get a raster with no nodata value defined since
this is what they provided. However in the case the geometry is not a
rectangle aligned with the raster (e.g a circle), there must be a way to
set some pixels to nodata.
When the provided raster have a nodata defined, this nodata value is used.
No problem.
When an array of nodata value is provided, those nodata values are used.
No problem.
There is no such need in the case where the geometry is a rectangular
fraction of the raster extent or when the geometry encompasses the raster
and hence there is no need to set a nodata value in the resulting raster
but we have no way to know that.
When both of those conditions are not met (the provided raster do not have
a nodata defined AND no array of nodata value is provided) and hence
absolutely no nodata value is known, instead of imposing
ST_MinPossibleValue() we should just NOTICE the user that we could not set
a nodata value and that if he wants one to be defined he must use one of
the variant accepting nodata values (or set a nodata value to its raster
before clipping).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1581>
