[postgis-devel] [PostGIS] #1571: ST_ChangeEdgeGeom lets you break topology
PostGIS trac at osgeo.org
Thu Feb 16 09:52:30 PST 2012
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.1.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Changes (by strk):
  * milestone:  PostGIS 2.0.0 => PostGIS 2.1.0
Comment:
 I wonder if the semantic for this function should be: you should be able
 to drag the edge shape around hitting _no_ obstacle. Sounds like a
 topology prescription, although I'm not using correct terms.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1571#comment:4>
