[postgis-devel] st_pointonsurface fails
James Sewell
James.Sewell at lisasoft.com
Thu Feb 16 16:44:56 PST 2012
Hello,
I've discovered a supposed valid (but very thin) geometry which ST_PointOnSuface fails on:
\001\003\000\000\000\001\000\000\000\006\000\000\000\011\030<\314\317\034b@\222
(\333\354\304\354B\300\036)\004m\320\034b@\214\013V\210\306\354B\300/\273$\343\3
20\034b@\272\344\275\262\307\354B\300\325\311\201m\320\034b@\307\255\216\213\306
\354B\300\332^\315-\320\034b@\277>\216\346\305\354B\300\011\030<\314\317\034b@\2
22(\333\354\304\354B\300
This is on the following:
POSTGIS="2.0.0SVN" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.7.1, 23 September 2009"
LIBXML="2.6.26" USE_STATS
I presume it has something to do with being so thin, but it comes up valid so it must have a least one internal point to be a polygon ... right?
Cheers,
James Sewell
Solutions Architect
LISAsoft
Ph: +61 3 8680 3250 Fax: +61 3 8680 3299
Level 9, 601 Bourke St, Melbourne Vic 3000
http://www.lisasoft.com<http://www.lisasoft.com/>
The contents of this email are confidential and may be subject to legal or professional privilege and copyright. No representation is made that this email is free of viruses or other defects. If you have received this communication in error, you may not copy or distribute any part of it or otherwise disclose its contents to anyone. Please advise the sender of your incorrect receipt of this correspondence.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120217/84249e15/attachment.html>
