[postgis-devel] [PostGIS] #1571: ST_ChangeEdgeGeom lets you break topology
PostGIS trac at osgeo.org
Fri Feb 17 00:35:03 PST 2012
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Changes (by strk):
  * milestone:  PostGIS 2.1.0 => PostGIS 2.0.0
Comment:
 Replying to [comment:5 strk]:
 > Next step would be algorithmically: how to find out if the constraint
 gets broken by a movement ?
 A night over it and here's the answer: form a polygon merging old and new
 edge, if the polygon contains any node then the movement broke the
 constraint. Corner case: a closed edge changing winding (must be treated
 specially)
 I can do it for 2.0 !
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1571#comment:6>
