[postgis-devel] [PostGIS] #1570: in_gml crashing and many regrss tests failing on mingw (was: in_gml, in_kml crashing and many regrss tests failing on mingw)
trac at osgeo.org
Sun Feb 19 23:52:05 PST 2012
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
Okay I think I got it this time: r8963
I'll go back one version just to confirm -- but I tested up thru r8951 and
all those were fine and the ones between r8951 and r8963 seem mostly like
harmless topology changes. I tested r8963 and bam. I was also wrong it
is just st_geomfromGML that is affected. kml failed because the
geomfromgml test crashed my server.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1570#comment:17>
