[postgis-devel] new regression failure: raster comments
Sandro Santilli
strk at keybit.net
Mon Feb 20 03:01:47 PST 2012
On Sat, Feb 18, 2012 at 10:19:40AM -0500, Greg Troxel wrote:
> I've been updating and rerunning build/check/etc. for a while, and gmake
> check has been completing ok (postgis, rsater, topology). Just recently
> I started getting an error, and a run on r9382 produced:
> psql:/home/gdt/SOFTWARE/POSTGIS/postgis/regress/00-regress-install/share/contrib/postgis/raster_comments.sql:322: ERROR: syntax error at or near "BOTH" LINE 1: ...egprocedure ) IS 'args: rast1, rast2, returnband='BOTH', oth...
> and line 322 of raster_comments.sql has ' inside a string that's quoted
> with '.
> Line 3261 of rtpostgis.sql.in has "DEFAULT 'both'".
> but was last touched at r8434.
I'm getting the same failure, could you please file a ticket for it ?
> Are the inner ' supposed to get protected from interpretation somehow?
Yes, most likely. But it's evidently failing.
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.0 !
| / 2.0 | http://strk.keybit.net
`-o------'
