[postgis-devel] [PostGIS] #1588: [raster] regression failure due to underquoting
trac at osgeo.org
Mon Feb 20 04:52:35 PST 2012
Reporter: gdt | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: raster | Version: trunk
Keywords: |
In r9235 (and I believe due to a change within the last week), make
check fails in raster with
Creating spatial db postgis_reg
createlang: language "plpgsql" is already installed in database
"postgis_reg"
Adding raster support
Something went wrong during db initialization (raster comments).
For details, check /tmp/pgis_reg_7747/regress_log
which contains
psql:/home/gdt/SOFTWARE/POSTGIS/postgis/regress/00-regress-
install/share/contrib/postgis/raster_comments.sql:322: ERROR: syntax
error at or near "BOTH"
LINE 1: ...egprocedure ) IS 'args: rast1, rast2, returnband='BOTH', oth...
This is due, I think, to the following in raster/rt_pg/rtpostgis.sql.in:
CREATE OR REPLACE FUNCTION st_intersection(
rast1 raster,
rast2 raster,
returnband text DEFAULT 'BOTH',
otheruserfunc regprocedure DEFAULT NULL
RETURNS raster AS
$$ SELECT st_intersection($1, 1, $2, 1, $3, $4) $$
LANGUAGE 'sql' STABLE;
The problem seems to be that the single quotes around BOTH are not
themselves quoted when used inside a dcoumentation string.
I observed the problem with
PostGIS is now configured for i386-unknown-netbsdelf5.1.
-------------- Compiler Info -------------
C compiler: gcc -g -O2
C++ compiler: g++ -g -O2
-------------- Dependencies --------------
GEOS config: /usr/pkg/bin/geos-config
GEOS version: 3.3.2
GDAL config: /usr/pkg/bin/gdal-config
GDAL version: 1.8.1
PostgreSQL config: /usr/pkg/bin/pg_config
PostgreSQL version: PostgreSQL 9.1.2
PROJ4 version: 47
Libxml2 config: /usr/pkg/bin/xml2-config
Libxml2 version: 2.7.8
JSON-C support: no
PostGIS debug level: 0
Perl: /usr/pkg/bin/perl
but strk reports seeing it as well, so it's not a NetBSD-specific
issue.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1588>
