[postgis-devel] [PostGIS] #964: Support for PostgreSQL 9.1+ new	Extensions model
    trac at osgeo.org
    Mon Feb 20 07:05:02 PST 2012
 Reporter:  robe         |       Owner:  robe
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by strk):
 I just tested a "make && make install" and then did the "CREATE EXTENSION"
 and everything seems to be working. So the install part seems good.
 Do we want to use the CREATE EXTENSION model on "make check" too for 9.1 ?
 Does it make sense to also test the other (old) way in 9.1 ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/964#comment:9>
