[postgis-devel] [PostGIS] #964: Support for PostgreSQL 9.1+ new Extensions model
trac at osgeo.org
Mon Feb 20 11:57:24 PST 2012
Reporter: robe | Owner: robe
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
Makes sense to also test old I think because there is no way right now to
upgrade 9.1 between non-tagged versions. So for example in theory you can
upgrade from alpha2 to alpha5 with extensions but you can't go from an
alpha6SVN to another alpha6SVN because there is no unique versioning.
Although would be good to add to our list of testing the extension version
piece. I didn't have an old alpha* handy to upgrade last time I did an
experimental build release.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/964#comment:11>
