[postgis-devel] [PostGIS] #1591: ST_GeomFromGML crushes for Triangle (Triangulard Surface/TIN)
trac at osgeo.org
Mon Feb 20 13:16:59 PST 2012
Reporter: itboyet | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: 2.0.x
Keywords: |
I am trying to use the ST_GeomFromGML to insert some TIN/Triangular Object
into Postgres database; however, PostGIS/PostgreSQL exits after I executed
the following query:
SELECT ST_AsEWKT(ST_GeomFromGML('
<gml:TriangulatedSurface>
<gml:TrianglePatches>
<gml:Triangle>
<gml:exterior>
<gml:LinearRing gml:id="1">
<gml:posList srsDimension="3">
0 0 1000000
0 10 1000000
10 10 1000000
0 0 1000000
</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Triangle>
<gml:Triangle>
<gml:exterior>
<gml:LinearRing gml:id="2">
0 0 8000000
10 10 1000000
0 0 1000000
0 0 8000000
</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Triangle>
<gml:Triangle>
<gml:exterior>
<gml:LinearRing gml:id="3">
0 0 8000000
0 10 1000000
10 10 1000000
0 0 8000000
</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Triangle>
<gml:Triangle>
<gml:exterior>
<gml:LinearRing gml:id="4">
0 0 8000000
0 0 1000000
0 10 1000000
0 0 8000000
</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Triangle>
</gml:TrianglePatches>
</gml:TriangulatedSurface>'));
However, it would give me an actual error if I change the tag
"TriangulatedSurface" to "TriangularSurface", which should not be the
correct gml tag.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1591>
