[postgis-devel] [PostGIS] #1594: AddGeometryColumns has a problem with certain SRID's
trac at osgeo.org
Tue Feb 21 06:46:51 PST 2012
Reporter: soi | Owner: pramsey
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.5.X
Keywords: |
AddGeometryColumns() reports lots of given SRID's (all i tested it with
except -1) as invalid but at the same time it is possible to change the
SRID with UpdateGeometrySRID(). Corrensponding logs follow.
2012-02-20 14:52:27 CET LOG: statement: CREATE TABLE "shape_basin" (gid
serial PRIMARY KEY,
"sampleid" varchar(50),
"area" float8);
2012-02-20 14:52:46 CET LOG: statement: SELECT
AddGeometryColumn('','shape_basin','the_geom',4326,'MULTIPOLYGON',2);
2012-02-20 14:52:46 CET ERROR: AddGeometryColumns() - invalid SRID
However this is possible:
2012-02-20 14:55:21 CET LOG: statement: SELECT
AddGeometryColumn('','shape_basin','the_geom',-1,'MULTIPOLYGON',2);
2012-02-20 14:55:57 CET LOG: statement: SELECT
UpdateGeometrySRID('shape_basin', 'the_geom', 4326);
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1594>
