[postgis-devel] [PostGIS] #1595: problem with geom from ST_Line_SubString
trac at osgeo.org
Tue Feb 21 08:14:18 PST 2012
Reporter: worthlutz | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 1.5.4
Component: postgis | Version: 1.5.X
Keywords: ST_Line_Substring |
Mapserver will not display in a Line layer the_geom returned from
ST_Line_Substring(). In looking into this, I noticed that the geometry
from ST_Line_Substring is different from the original geometry. This was
1st noticed in the text representations of the geometry. The text
representations of the substring has "SRID=32019;" added before the points
in the text after "MULTILINESTRING(".
The geometry representation is also different. See results from the
SQL below. Note the substring is the entire string to be able to compare
the two geometry results. I assume they should be the same.
SELECT
the_geom as orig_geom,
ST_Line_Substring( the_geom, 0.0, 1.0 ) AS substring_geom,
ST_AsText( the_geom ) AS original_text,
ST_AsText(
) AS substring_text,
ST_AsEWKT( the_geom ) AS original_EWKT,
ST_AsEWKT(
) AS substring__EWKT
FROM (
SELECT
ST_SetSRID(
ST_GeomFromText(
'MULTILINESTRING((2108912.024 773324.5672,2109137.75 773640.25))'
32019
) AS the_geom
) AS foo
I do not know if these items are why Mapserver will not display the
geometry but they looked strange. Openjump will display the geometry
which may point to a problem with Mapserver. Point me there is that is the
case. Mapserver will display the endpoints of the substring geometry with
ST_EndPoint(the_geom) in a Point layer.
I am working on a simple Mapserver example to attach.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1595>
