[postgis-devel] [PostGIS] #1595: problem with geom from ST_Line_SubString
PostGIS trac at osgeo.org
Tue Feb 21 08:51:55 PST 2012
  Reporter:  worthlutz  |       Owner:  pramsey
      Type:  defect     |      Status:  closed
  Priority:  critical   |   Milestone:  PostGIS 1.5.4
 Component:  postgis    |     Version:  1.5.X
Resolution:  fixed      |    Keywords:  ST_Line_Substring
Changes (by strk):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 ok, the issue is indeed in the line_substring call, only isn't revealed by
 2.0 because there we don't care about SRID of inner geometries when it
 comes to output.
 It's fixed in 1.5 branch as of r9250 -- not sure how to test it with 2.0,
 it would take a smarter ST_Summary to figure.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1595#comment:4>
