[postgis-devel] [PostGIS] #1598: Use consistent UNIX line endings
trac at osgeo.org
Wed Feb 22 10:28:46 PST 2012
Reporter: mwtoews | Owner: chodgson
Type: task | Status: new
Priority: low | Milestone: PostGIS 2.0.0
Component: management | Version: trunk
Keywords: |
Comment(by pramsey):
Full list
./doc/html/image_src/st_azimuthmath.sql
./doc/xsl/post_gis_day_cards.html.xsl
./doc/xsl/postgis_cheatsheet.html.xsl
./doc/xsl/postgis_comments.sql.xsl
./doc/xsl/raster_cheatsheet.html.xsl
./doc/xsl/raster_comments.sql.xsl
./doc/xsl/tiger_geocoder_cheatsheet.html.xsl
./doc/xsl/tiger_geocoder_comments.sql.xsl
./doc/xsl/topology_cheatsheet.html.xsl
./doc/xsl/topology_comments.sql.xsl
./extensions/postgis/META.json
./extensions/postgis_topology/META.json
./extras/tiger_geocoder/README
./extras/tiger_geocoder/tiger_2006andbefore/orig/tiger_geocoder.sql
./extras/tiger_geocoder/tiger_2006andbefore/README
./extras/tiger_geocoder/tiger_2010/create_geocode.bat
./extras/tiger_geocoder/tiger_2010/legacy_import/tiger2008/import_tiger_shps.sh
./extras/tiger_geocoder/tiger_2010/upgrade_geocoder.bat
./liblwgeom/lwout_x3d.c
./liblwgeom/measures3d.c
./liblwgeom/measures3d.h
./loader/shp2pgsql-gui.rc
./postgis/lwgeom_export.c
./postgis/lwgeom_rtree.h
./postgis/postgis.sql.in.c
./raster/scripts/plpgsql/st_addband.sql
./raster/scripts/plpgsql/st_geomextent2rastercoord.sql
./raster/scripts/plpgsql/st_mapalgebra_optimized.sql
./raster/scripts/plpgsql/st_multibandmapalgebra.sql
./raster/scripts/plpgsql/st_pixelaspoints.sql
./raster/scripts/plpgsql/st_querytables.sql
./raster/scripts/plpgsql/st_tile.sql
./raster/test/regress/create_rt_empty_raster_test.sql
./raster/test/regress/rt_hasnoband.sql
./raster/test/regress/rt_isempty.sql
./regress/concave_hull.sql
./regress/regress_index_nulls.sql
./regress/regress_lots_of_nulls.sql
./regress/regress_management.sql
./regress/sql-mm-circularstring.sql
./regress/sql-mm-compoundcurve.sql
./regress/sql-mm-curvepoly.sql
./regress/sql-mm-general.sql
./regress/sql-mm-multicurve.sql
./regress/sql-mm-multisurface.sql
./regress/sql-mm-serialize.sql
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1598#comment:2>
