[postgis-devel] [PostGIS] #1586: [raster] st_dumpaspolygons makes not valid polygons
PostGIS trac at osgeo.org
Wed Feb 22 15:22:30 PST 2012
 Reporter:  jomarlla  |       Owner:  dustymugs
     Type:  defect    |      Status:  assigned
 Priority:  high      |   Milestone:  PostGIS 2.0.0
Component:  raster    |     Version:  trunk
 Keywords:            |
Comment(by dustymugs):
 So for a simple bow-tie situation, ST_DumpAsPolygons returns two polygons
 WITH foo AS (
         SELECT
                 ST_SetValue(
                         ST_SetValue(
                                 ST_AddBand(
                                         ST_MakeEmptyRaster(2, 2, 0, 0, 1,
 1, 0, 0, 0)
                                         , '8BUI'::text, 0, 0
                                 , 1, 1, 1
                         , 2, 2, 1
                 ) AS rast
 SELECT
         ST_AsText((ST_DumpAsPolygons(rast)).geom)
 FROM foo
 Need to find an example of a raster dumping invalid polygons.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1586#comment:9>
