[postgis-devel] [PostGIS] #1606: upgrade script failure: error can not change name of input parameter "new_srid"
PostGIS trac at osgeo.org
Thu Feb 23 02:35:16 PST 2012
"new_srid"
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by strk):
 Changing again would mean that the upgrade will fail for anyone going from
 alpha6 to alpha7,
 but those going from alpha5 to alpha7 would be fine.
 Better go with the drop, probably.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1606#comment:5>
