[postgis-devel] [PostGIS] #1609: [raster] Implement ST_Merge for ST_Union
trac at osgeo.org
Thu Feb 23 07:01:05 PST 2012
Reporter: pracine | Owner: pracine
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: raster | Version: trunk
Keywords: |
Tentative signature:
ST_Merge(raster1, band1, raster2, band2, nodataval, pixeltype)
Merge two rasters together by unioning their extent and burning the last
raster without taking the other raster pixel values into account. Works on
multiple bands. The nodata value, when specified, replace the existing
nodata values. SRIDs must be the same for the two rasters.
The goal of this function is to be used by ST_union when unioning rasters
with the 'LAST' option.
It could be first easily implemented as a wrapper around ST_MapAlgebra.
Ideally it should be a C function that we could actually use to optimize
the two rasters ST_MapAlgebra in certain situations (when extentype is
INTERSECTION and the expression is 'RAST2' and there is no alternative
expressions).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1609>
