[postgis-devel] Objects versioning
Paul Ramsey pramsey at opengeo.org
Fri Feb 24 06:32:18 PST 2012
I can live with it, I'm pretty sure.
+1
On Fri, Feb 24, 2012 at 2:33 AM, Sandro Santilli <strk at keybit.net> wrote:
> I think it is time to simplify and improve robustness of versioning.
> The current situation is weak in that there's no version stored/checked
> inside the raster library nor in the raster or topology scripts.
> Also the current version stored/checked for core lib/scripts isn't
> necessarely correct because it relies on SVN keyword substitution
> performed on the main file and thus doesn't catch modifications
> happening in included files. Not to mention that under git-svn
> the keyword substitution doesn't happen...
> I've created a ticket for this:
> http://trac.osgeo.org/postgis/ticket/1608
> But it's probably better to discuss on the list first.
> My proposal is as follows:
>  1) PostGIS has a single version for all components.
>    Such version is Major.Minor.Micro plus an optional
>    revision number (for SVN snapshots)
>  2) The PostGIS single version should be stored in all
>    libraries (core,raster) and user-facing scripts
>    (postigs.sql, rtpostgis.sql, topology.sql).
>  3) Each script should expose function to report
>    the version it embeds. Scripts bound to libraries
>    should also expose a function to report the version
>    of the bound library (core, raster).
>  4) The postgis_full_version() should check for the
>    version reported by all the functions as being equal
>    or suggest appropriate action to fix any discrepancy.
> The worst case I can see with this approach is that people are
> requested to run the "upgrade_minor" script more often than
> otherwise needed, but I see absolutely no harm in doing that,
> as long as our "upgrade_minor" scripts are working.
> I'd like to get this done before beta, so please cast your votes !
> Thank you.
> --strk;
>  ,------o-.
>  |   __/  |    Delivering high quality PostGIS 2.0 !
>  |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
>  `-o------'
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
