[postgis-devel] [PostGIS] #1617: several regress failures on raster (old mingw)
PostGIS trac at osgeo.org
Sat Feb 25 18:47:56 PST 2012
 Reporter:  robe     |       Owner:  pracine
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  raster   |     Version:  trunk
 Keywords:           |
 IT's been a while since I've tested raster since before the core postgis
 tests were failing.  Now that all those past after Paul's fixes -- thanks
 Paul :)
 I'm seeing failures in raster.  Also for some reason my temp folder is not
 being numbered anymore.  It's putting the results in
 Appdata\Local\Temp\pgis_reg  instead of
 Appdata\Local\Temp\pgis_reg_somerandomnumber
  PostgreSQL 9.1.2, compiled by Visual C++ build 1500, 32-bit
  Postgis 2.0.0alpha7SVN - r - 2012-02-26 02:29:02
    GEOS: 3.3.3dev-CAPI-1.7.3
    PROJ: Rel. 4.6.1, 21 August 2008
    GDAL: GDAL 1.9.0, released 2011/12/29
 Running tests
  check_raster_columns .. ok
  check_raster_overviews .. ok
  rt_io .. ok
  rt_bytea .. ok
  box3d .. ok
  rt_addband .. ok
  rt_band .. ok
  rt_asgdalraster .. failed (diff expected obtained:
 /tmp/pgis_reg/test_8_diff)
  rt_astiff .. failed (diff expected obtained: /tmp/pgis_reg/test_9_diff)
  rt_asjpeg .. failed (diff expected obtained: /tmp/pgis_reg/test_10_diff)
  rt_aspng .. ok
  rt_union .. ok
  create_rt_properties_test .. ok
  rt_dimensions .. ok
  rt_scale .. ok
  rt_pixelsize .. ok
  rt_upperleft .. ok
  rt_rotation .. ok
  rt_georeference .. ok
  rt_set_properties .. ok
  drop_rt_properties_test .. ok
  create_rt_empty_raster_test .. ok
  rt_isempty .. ok
  rt_hasnoband .. ok
  drop_rt_empty_raster_test .. ok
  rt_metadata .. ok
  create_rt_band_properties_test .. ok
  rt_band_properties .. ok
  rt_set_band_properties .. ok
  rt_summarystats .. ok
  rt_count .. ok
  rt_histogram .. ok
  rt_quantile .. ok
  rt_valuecount .. ok
  rt_valuepercent .. ok
  rt_bandmetadata .. ok
  rt_pixelvalue .. ok
  drop_rt_band_properties_test .. ok
  rt_utility .. ok
  create_rt_mapalgebra_test .. ok
  rt_mapalgebraexpr .. ok
  rt_mapalgebrafct .. ok
  rt_mapalgebraexpr_2raster .. ok
  rt_mapalgebrafct_2raster .. ok
  drop_rt_mapalgebra_test .. ok
  create_rt_mapalgebrafctngb_test .. ok
  rt_mapalgebrafctngb .. ok
  rt_mapalgebrafctngb_userfunc .. ok
  drop_rt_mapalgebrafctngb_test .. ok
  rt_reclass .. ok
  rt_resample .. ok
  rt_asraster .. ok
  rt_intersection .. ok
  rt_clip .. ok
  create_rt_gist_test .. ok
  rt_above .. ok
  rt_below .. ok
  rt_contained .. ok
  rt_contain .. ok
  rt_left .. ok
  rt_overabove .. ok
  rt_overbelow .. ok
  rt_overlap .. ok
  rt_overleft .. ok
  rt_overright .. ok
  rt_right .. ok
  rt_same .. ok
  drop_rt_gist_test .. ok
  rt_spatial_relationship .. ok
  rt_intersects .. ok
  rt_samealignment .. ok
  bug_test_car5 .. ok
  tickets .. ok
  loader/Basic .... failed ( test: actual SQL does not match expected.,:
 /tmp/pgis_reg/loader.out)
 .. ok
  loader/BasicCopy .... failed ( test: actual SQL does not match
 expected.,: /tmp/pgis_reg/loader.out)
 .. ok
  loader/Tiled10x10 ..... ok
  loader/Tiled10x10Copy ..... ok
  uninstall ... ok (3855)
 Run tests: 78
 Failed: 5
 The rt_asgdalraster is crashing my service.  I suspect astiff and asjpeg
 are failing becasue they are being running while the pg service is
 starting up.
 I've attached the regress folder
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1617>
