[postgis-devel] [PostGIS] #1617: [raster] several regress failures on raster (old mingw)
PostGIS trac at osgeo.org
Sun Feb 26 11:20:55 PST 2012
 Reporter:  robe     |       Owner:  pracine
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  raster   |     Version:  trunk
 Keywords:  mingw    |
Comment(by robe):
 On mine it says its successful
 make -C test check
 make[1]: Entering directory `/c/projects/PostGIS/trunk/raster/test'
 make -C core check
 make[2]: Entering directory `/c/projects/PostGIS/trunk/raster/test/core'
 ./testapi
 Warning 6: PNG driver doesn't support data type Int16. Only eight bit
 (Byte) and sixteen bit (UInt16) bands supported. Defaulting to Byte
 Checking empty and hasnoband functions...
 Checking raster properties...
 Raster starts with 0 bands
 First point on convexhull ring is 0.5,0.5
 Second point on convexhull ring is 256.5,1280.5
 Third point on convexhull ring is 1280.5,1536.5
 Fourth point on convexhull ring is 1024.5,256.5
 Fifth point on convexhull ring is 0.5,0.5
 Testing rt_raster_gdal_polygonize
 Successfully tested rt_raster_gdal_polygonize
 Testing 1BB band
 Testing 2BB band
 Testing 4BUI band
 Testing 8BUI band
 Testing 8BSI band
 Testing 16BSI band
 ERROR: rt_band_set_pixel: Coordinates out of range
 Testing 16BUI band
 Testing 32BUI band
 Testing 32BSI band
 Testing 32BF band
 Testing 64BF band
 Testing band hasnodata flag
 Testing rt_raster_from_band
 Successfully tested rt_raster_from_band
 Testing band stats
 Successfully tested band stats
 Testing rt_raster_replace_band
 Successfully tested rt_raster_replace_band
 Testing rt_band_reclass
 Successfully tested rt_band_reclass
 Testing rt_raster_to_gdal
 Successfully tested rt_raster_to_gdal
 Testing rt_raster_gdal_drivers
 Successfully tested rt_raster_gdal_drivers
 Testing rt_band_get_value_count
 Successfully tested rt_band_get_value_count
 Testing rt_raster_from_gdal_dataset
 Successfully tested rt_raster_from_gdal_dataset
 Testing rt_util_compute_skewed_extent
 Successfully tested rt_util_compute_skewed_extent
 Testing rt_raster_gdal_warp
 Successfully tested rt_raster_gdal_warp
 Testing rt_raster_gdal_rasterize
 Successfully tested rt_raster_gdal_rasterize
 Testing rt_raster_intersects
 Successfully tested rt_raster_intersects
 Testing rt_raster_same_alignment
 Successfully tested rt_raster_same_alignment
 Testing rt_raster_from_two_rasters
 ERROR: rt_raster_from_two_rasters: The two rasters provided do not have
 the same alignment
 the same SRID
 the same alignment
 Successfully tested rt_raster_from_two_rasters
 Testing rt_raster_load_offline_band
 Successfully tested rt_raster_load_offline_band
 ./testwkb
  in hexwkb len: 122
 out hexwkb len: 122
  in hexwkb:
 00000000003FF0000000000000400000000000000040080000000000004010000000000000401400000000000040180000000000000000000A00070008
 out hexwkb:
 0100000000000000000000F03F000000000000004000000000000008400000000000001040000000000000144000000000000018400A00000007000800
  in hexwkb len: 128
 out hexwkb len: 128
  in hexwkb len: 138
 out hexwkb len: 138
  in hexwkb len: 152
 out hexwkb len: 152
  in hexwkb len: 152
 out hexwkb len: 152
 ext band path: /tmp/t.tif
 ext band  num: 3
  in hexwkb len: 152
 out hexwkb len: 152
 SRID value -1 converted to the officially unknown SRID value 0
  in hexwkb len: 284
 out hexwkb len: 284
  in hexwkb len: 284
 out hexwkb len: 284
  in hexwkb len: 284
 out hexwkb len: 284
  in hexwkb len: 284
 out hexwkb len: 284
  in hexwkb len: 284
 out hexwkb len: 284
 All tests successful !
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1617#comment:9>
