[postgis-devel] [PostGIS] #1617: [raster] several regress failures on raster (old mingw)
PostGIS trac at osgeo.org
Sun Feb 26 11:28:43 PST 2012
 Reporter:  robe     |       Owner:  pracine
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  raster   |     Version:  trunk
 Keywords:  mingw    |
Comment(by robe):
 Paul,
 So are you saying the testapi test is crashing for you?  If that is the
 case might be the interaction between vcc and native ming.  In my case the
 testapi would be a pure mingw gdal test since my gdal is compiled under
 mingw and that test doesn't touch postgresql.  So I wouldn't see the
 interaction until my PostgreSQL test which is a test against a PostgreSQL
 VC++ build.
 So could be at the point where it is trying to output the error something
 is not being closed right.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1617#comment:11>
