[postgis-devel] [PostGIS] #1536: [raster] There should be an option for setting the nodata value in certain variants of ST_Intersection(raster, raster)
trac at osgeo.org
Mon Feb 27 11:09:57 PST 2012
Reporter: pracine | Owner: pracine
Type: defect | Status: assigned
Priority: low | Milestone: PostGIS 2.0.0
Component: raster | Version: trunk
Keywords: |
Comment(by pracine):
I redesigned the variants if I add a double precision[] nodataval
parameter. I end up with: (= means this parameter has a default value. I
shortened everything for ease of reading)
-- raster/geometry[[BR]]
rast, geom, reg[[BR]]
rast, geom, nodata=, reg=[[BR]]
rast, band, geom, reg[[BR]]
rast, band, geom, nodata=, reg=
-- raster/raster no band number[[BR]]
ras1, rast2, return=, nodaval[]=, reg=[[BR]]
ras1, rast2, return=, nodaval=, reg=[[BR]]
ras1, rast2, nodaval[], reg= (opt)[[BR]]
ras1, rast2, nodaval, reg= (opt)[[BR]]
ras1, rast2, reg (opt)
-- raster/raster with band number[[BR]]
ras1, b1, rast2, b2, return=, nodaval[]=, reg=[[BR]]
ras1, b1, rast2, b2, return=, nodaval=, reg=[[BR]]
ras1, b1, rast2, b2, nodaval[], reg= (opt)[[BR]]
ras1, b1, rast2, b2, nodaval, reg= (opt)[[BR]]
ras1, b1, rast2, b2, reg (opt)
Maybe we can simplify by removing the three last one (the opt ones) of the
two last groups and force users to pass something or a casted NULL in one
of the two first one?
Could we, in the doc, when we have parameter accepting a single value or
an array, like here the new nodataval parameter, not list the variants
accepting an array and simply say in the doc "Every of those variant also
accept an array of value"?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1536#comment:26>
