[postgis-devel] [PostGIS] #1623: Can't compile anymore under mingw 3.4.5
PostGIS trac at osgeo.org
Mon Feb 27 20:39:46 PST 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 did something change between yesterday and  otday.  I don't think I
 changed anything but now I'm getting this error:
 lwin_wkt_lex.c:693: warning: no previous prototype for 'wkt_yylex'
 lwin_wkt_lex.c: In function `wkt_yylex':
 lwin_wkt_lex.c:785: error: `yylineno' undeclared (first use in this
 function)
 lwin_wkt_lex.c:785: error: (Each undeclared identifier is reported only
 once
 lwin_wkt_lex.c:785: error: for each function it appears in.)
 make[1]: *** [lwin_wkt_lex.lo] Error 1
 make[1]: Leaving directory `/c/projects/PostGIS/trunk/liblwgeom'
 make: *** [all] Error 1
 /bin/perl utils/svn_repo_revision.pl
 Can't fetch SVN revision: no svn executable found
 Not updating existing rev file at 0
 I can add svn to my path and see if that fixes the issue but not sure why
 SVN is suddenly a requirement.  I assume it will not be for tar balls.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1623>
