[postgis-devel] [PostGIS] #1623: Can't compile anymore under mingw 3.4.5
trac at osgeo.org
Mon Feb 27 22:09:24 PST 2012
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
FWIW: this is what I get with a clean checkout.
* Running /mingw/bin/libtoolize (2.2.10)
OPTIONS = --force --copy --install
libtoolize: putting auxiliary files in `.'.
libtoolize: copying file `./config.guess'
libtoolize: copying file `./config.sub'
libtoolize: copying file `./install-sh'
libtoolize: copying file `./ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `macros'.
libtoolize: copying file `macros/libtool.m4'
libtoolize: copying file `macros/ltoptions.m4'
libtoolize: copying file `macros/ltsugar.m4'
libtoolize: copying file `macros/ltversion.m4'
libtoolize: copying file `macros/lt~obsolete.m4'
libtoolize: Consider adding `-I macros' to ACLOCAL_AMFLAGS in Makefile.am.
* Running /mingw/bin/aclocal (1.11)
' is already registered with AC_CONFIG_FILES.
../../lib/autoconf/status.m4:290: AC_CONFIG_FILES is expanded from...
configure.ac:1024: the top level
/bin/m4: cannot remove temporary directory /tmp/m4-S7qpxB: Directory not
empty
autom4te: /bin/m4 failed with exit status: 1
aclocal: autom4te failed with exit status: 1
Something went wrong, giving up!
Yes things are really bad when your dev env gives up.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1623#comment:2>
