[postgis-devel] [PostGIS] #1624: Do not download DTD
PostGIS trac at osgeo.org
Tue Feb 28 02:33:21 PST 2012
 Reporter:  strk                   |       Owner:  strk
     Type:  task                   |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
 Prevent DTD downloading while producing the documentation.
 This is similar to #963 but for general use, not only for Hudson.
 Since r9327 we have the support in place to look for offline mathml2.dtd
 and could expand on it. This ticket is to forbid network access (--nonet
 switch to xsltproc) and provide all it takes to make it possible (a
 configure switch to explicitly name the place where you can find the DTDs,
 for example).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1624>
