[postgis-devel] [PostGIS] #1613: Cannot achieve toTopoGeom
trac at osgeo.org
Tue Feb 28 06:25:35 PST 2012
Reporter: 3nids | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: 2.0.x
Keywords: |
Comment(by strk):
Ok, what's happening is that the code fails snapping the first line to the
intersection with the second line.
Try this:
select ST_AsText(ST_Snap('LINESTRING(556267.562954 144887.066638,556267
144887.4)'::geometry, 'POINT(556267.55881132 144887.069091153)'::geometry,
1e-12));
You'll see the edge remains a 2-points edge.
1e-12 is an arbitrary tolerance hard-coded into the TopoGeo_AddPoint, only
because ST_Snap needs a tolerance to do its thing. If you make it bigger
you get the 3-vertex result. If you make it too big it gets back to 2
vertex snapping to the first vertex whose distance is below the tolerance.
Not an easy problem to solve. The whole reason to snap is because the
ST_ModEdgeSplit (and ST_NewEdgesSplit) insist on the "splitting-vertex" to
be _within_ the edge, which is close to impossible to achieve... The
SQL/MM specs do not include any reference about accepting tolerances in
there.
Finally, it turns out that ST_Within and ST_DWithin(0) disagree about the
matter being:
is '010100000070841C1ED7F9204187A97F8DB8AF0141'::geometry
within
'010200000002000000B6813B20D7F92041F5807988B8AF014100000000D6F9204133333333BBAF0141'::geometry
So bottomline:
=# with inp as ( select
'010100000070841C1ED7F9204187A97F8DB8AF0141'::geometry as p,
as l ) select ST_AsText(l) as l, ST_AsText(p) as p, ST_Within(p, l) as
within, ST_DWithin(p, l, 0) as dwithin from inp;
-[ RECORD 1 ]----------------------------------------------------
l | LINESTRING(556267.562954 144887.066638,556267 144887.4)
p | POINT(556267.55881132 144887.069091153)
within | f
dwithin | t
Worth a sub-ticket
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1613#comment:4>
