[postgis-devel] [PostGIS] #1625: ST_Within and ST_DWithin disagree
trac at osgeo.org
Tue Feb 28 09:31:28 PST 2012
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by nicklas):
strk
I would love to fix it, but as I wrote above I think it maybe is a bigger
discussion.
The quick fix (which I would hate) is to not project the point when
calling ST_Dwithin or ST_Distance.
The reason I wouldn't like that is because the consistence between the
results of st_shortestline and st_closestpoint and st_distance and
st_dwithin also has a value.
But I see no other fix since the projected point cannot have better
precision than it gets. So if st_shortestline really is to give the points
from where st_distance uses (which was the idea when writing the function)
this is what we get :-(
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1625#comment:7>
