[postgis-devel] circular dependency in doc/ ?
Chris Hodgson chodgson at refractions.net
Tue Feb 28 10:20:19 PST 2012
Is mathml2.dtd the ONLY thing that was slowing you down strk? There are
many other DTDs used, eg. docbook and docbook-mathml, and I thought that
some of those are dependent on eachother, so really the solution to this
is to properly configure your system's xml catalog. It seems like you're
going a long way out of your way to work around the pre-existing
solution of the xmlcatalog.
Chris
On 12-02-28 02:39 AM, Sandro Santilli wrote:
> On Tue, Feb 28, 2012 at 11:16:29AM +0100, Sandro Santilli wrote:
>> On Tue, Feb 28, 2012 at 11:05:40AM +0100, Sandro Santilli wrote:
>>> It is not clear to me why many targets under doc/ uses postgis.xml
>>> as input when the postgis.xml file also goes through keyword
>>> substitution becoming postgis-out.xml.
>>> Shouldn't postgis-out.xml be the input for further targets like
>>> comments and the like ?
>> Moreover: what's special about postgis-agg.xml, which is often
>> referenced in addition to postgis.xml ?
> I think I figured. r9327 reworks the dependency tracking while
> also adding lookup of mathml2.dtd on the filesystem.
> Now whoever has a slow doc generation please send the output
> of your "locate mathml2.dtd" and we'll add it to the list of
> scan directories of ./configure.ac
> The final report of ./configure will tell you now which one
> you're using. It'll be http://something for online (slow) and
> /something/else for filesystem (fast). Example:
>   -------- Documentation Generation --------
>    xsltproc:             /usr/bin/xsltproc
>    xsl style sheets:     /usr/share/xml/docbook/stylesheet/nwalsh
>    dblatex:              /usr/bin/dblatex
>    convert:              /usr/bin/convert
>    mathml2.dtd:          /usr/share/xml/schema/w3c/mathml/dtd/mathml2.dtd
> --strk;
>    ,------o-.
>    |   __/  |    Delivering high quality PostGIS 2.0 !
>    |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
>    `-o------'
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
