[postgis-devel] circular dependency in doc/ ?
Sandro Santilli
strk at keybit.net
Tue Feb 28 11:33:58 PST 2012
On Tue, Feb 28, 2012 at 11:22:27AM -0800, Chris Hodgson wrote:
> So I guess I can support the --nonet as the default, would be nice
> if there was an easy option to allow building without --nonet for a
> quick fix - quick as in effort, not elapsed time :)
An environment variable, maybe. Like RUNTESTFLAGS for "make check".
Should check if xsltproc supports a switch to disable --nonet in
order to override the default...
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.0 !
| / 2.0 | http://strk.keybit.net - http://vizzuality.com
`-o------'
