[postgis-devel] [PostGIS] #1631: SQL/MM Spatial exception - start node not geometry start point
PostGIS trac at osgeo.org
Wed Feb 29 02:32:57 PST 2012
 Reporter:  3nids     |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Comment(by 3nids):
 With debug output:
 Edge within 0 distance from node still does not contain the node after
 snapping to it with tolerance 2.00256322663555e-09
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1631#comment:2>
