[postgis-devel] circular dependency in doc/ ?
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Wed Feb 29 03:05:05 PST 2012
On 29/02/12 10:00, Sandro Santilli wrote:
>> An environment variable, maybe. Like RUNTESTFLAGS for "make check".
>> Should check if xsltproc supports a switch to disable --nonet in
>> order to override the default...
> In r9343 we have support for a XSLTPROCFLAGS. but I found no way
> to disable a --nonet switch so we need something smarter.
> What we could do is haveing XSLTPROCFLAGS default to --nonet if nothing
> is given, which means you can disable it using something like:
> make html XSLTPROCFLAGS=
Does xsltproc not have a download-only mode where it will download the
DTDs to a user-specified directory? Then we could invoke it once to do
that (assuming that it will finish quickly if there files aren't there),
and then a second time to actually do the build.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
