[postgis-devel] [PostGIS] #1634: Output confused for the function postgis_full_version()
trac at osgeo.org
Wed Feb 29 04:18:18 PST 2012
Reporter: lrssvt | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: 2.0.x
Keywords: |
Running the query select postgis_full_version(), in alpha7 subversion, I
get the following output:
"POSTGIS="2.0.0alpha7SVN" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.7.1, 23
September 2009" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8"
USE_STATS (core procs from "2.0.0alpha7SVN" need upgrade) (topology procs
from "2.0.0alpha7SVN" need upgrade) (raster procs from "2.0.0alpha7SVN"
need upgrade)"
same behavior is if I apply the three script SQL (postgis_[],rtpostgis_[]
and topology_[] - [upgrade_20_minor.sql])
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1634>
