[postgis-devel] raster and ~ operator in latest trunk vs r9240 ?
Sandro Santilli strk at keybit.net
Wed Feb 29 05:13:05 PST 2012
On Wed, Feb 29, 2012 at 01:43:51PM +0100, Nicklas Avén wrote:
> I can also change the binaries to latest trunk as long as I use the
> sql-functions from r9240 and it is still working.
> so this is working:
> "POSTGIS="2.0.0alpha7SVN" GEOS="3.4.0dev-CAPI-1.8.0" PROJ="Rel.
> 4.8.0, 20 February 2012" GDAL="GDAL 1.9.0, released 2011/12/29"
> LIBXML="2.7.8" SVN_REVISION=9347 USE_STATS (procs from 2.0 r9155
> need upgrade)"
> this is not working:
> "POSTGIS="2.0.0alpha7SVN r9347" GEOS="3.4.0dev-CAPI-1.8.0"
> PROJ="Rel. 4.8.0, 20 February 2012" GDAL="GDAL 1.9.0, released
> 2011/12/29" LIBXML="2.7.8" USE_STATS (core procs from
> "2.0.0alpha7SVN r9322" need upgrade) (raster procs from
> "2.0.0alpha7SVN r9322" need upgrade)"
> I also tried to upgrade the second one with
> rtpostgis_upgrade_20_minor.sql but get error:
> Error:  cannot drop function st_union(raster, text)because extension
> postgis requires it
Could you ticket this ?
Sounds like a missing entry in rtpostgis_drop.sql
I think most tickets from now on will be about upgrades and versioning
which we don't have an automated way of testing...
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.0 !
  |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
  `-o------'
