[postgis-devel] [PostGIS] #1630: upgrade from alpha6 to alpha7SVN -wktgeomval type can't be dropped
PostGIS trac at osgeo.org
Wed Feb 29 05:31:36 PST 2012
 Reporter:  robe                   |       Owner:  robe
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 strk -- actually if you could do it that would be great. I suspect its a
 function Pierre did but can't remember the one he did last and not near my
 compiler to even test.  I would like this to happen before Paul calls his
 beta. I assume the fact I called it a blocker will prevent him from going
 trigger happy :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1630#comment:3>
