[postgis-devel] [PostGIS] #1630: upgrade from alpha6 to alpha7SVN: wktgeomval type can't be dropped; cannot change input parameter nodata
PostGIS trac at osgeo.org
Wed Feb 29 06:14:50 PST 2012
  Reporter:  robe                   |       Owner:  strk
      Type:  defect                 |      Status:  closed
  Priority:  blocker                |   Milestone:  PostGIS 2.0.0
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:  fixed                  |    Keywords:
Changes (by strk):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 r9350 fixes the missing DROP, exposing next issue, which I'd file a
 separate bug for
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1630#comment:6>
