[postgis-devel] [PostGIS] #1634: Output confused for the function postgis_full_version()
PostGIS trac at osgeo.org
Wed Feb 29 08:20:26 PST 2012
  Reporter:  lrssvt   |       Owner:  pramsey
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  2.0.x
Resolution:           |    Keywords:
Comment(by strk):
 Replying to [comment:4 lrssvt]:
 > Replying to [comment:3 strk]:
 > > How did you obtain your sources ?
 > Download tar.gz from postgis.refractions.net
 (postgis-2.0.0alpha7SVN.tar.gz)
 > > Does the postgis_svn_revision.h contain a sensible revision number ?
 > #define POSTGIS_SVN_REVISION 0
 It's then a packaging error. You may need to wait next build of it. I
 dunno the build frequency.
 I expect next build to work correctly (have a non-zero
 POSTGIS_SVN_REVISION)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1634#comment:5>
