[postgis-devel] [PostGIS] #1427: totopogeom regress failure on 9.1
trac at osgeo.org
Tue Jan 3 04:40:46 PST 2012
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Keywords: |
Comment(by robe):
I usually try to avoid naming the parameters the same as column names to
avoid this issue (that's one thing I do like better about SQL Server
TransactSQL is you have to put an @ in front) -- which is why for my user
functions I always do param_.. so I always avoid the trap. That doesn't
work too well for a name to expose.
Anyrate you are violating your own model. I think your input argument
should be named
alayer. To follow your anedge, atopology (toponame) etc. that is already
well documented in the docs.
e.g. like you have here:
http://www.postgis.org/documentation/manual-svn/ST_AddIsoEdge.html
and your argument names should agree with what you have documented since
9.0+ people in theory (why they would I don't know except to be annoyingly
descriptive), can use named arg calling e.g.
SELECT ST_AddIsoEdge(toponame := 'mytopo', apoint := ST_Point(1,2) ...);
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1427#comment:2>
