[postgis-devel] [PostGIS] #1427: totopogeom regress failure on 9.1
PostGIS trac at osgeo.org
Tue Jan 3 14:15:05 PST 2012
  Reporter:  robe      |       Owner:  strk
      Type:  defect    |      Status:  closed
  Priority:  medium    |   Milestone:  PostGIS 2.0.0
 Component:  topology  |     Version:  trunk
Resolution:  fixed     |    Keywords:
Comment(by robe):
 confirmed for 9.0 you need drop: get this error:
 psql:totopogeom.sql:109: ERROR:  cannot change name of input parameter
 "geom"
 HINT:  Use DROP FUNCTION first.
 I'll open a separate ticket to put in a drop functions sql to fix these
 kind of things similar to what we have for raster and postgis which will
 get tacked on to upgrade minor script.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1427#comment:7>
